merc 150 overheating at idle and low speed
47aviator
I have a 1988 Merc 150 that overheats at an idle and low speed. Does fine when running medium to wide open speeds. Impeller has been recently changed.
bgbass.1
Re: merc 150 overheating at idle and low speed
check thermostat possibe not opening all the way. or you have a blockage
47aviator
Thanks for the info. How difficult is it to change the thermostat?
gss036
Easy as it gets as long as you don't break off one of the small bolts. Make sure you have 2 new thermostats & gaskets if you have 2 heads.
47aviator
Thanks for the help. I changed both t-stats and she's running great. That was easy.
