Merc 110 Lower Unit Rebuild ?
sswitzer916
hey all, im kinda jammed up with this rebuild.
i have to entire lower end disassembled. Im attempting to seat the forward gear and attached ball bearing back into the housing, but it just wont slide in.
im confused by this because all it took to get it out was a little tap on the housing.
anyone have any tips for me?
ive tried pounding it with a rubber mallet and am about to try pressing it with a giant clamp. is this the right direction or am i just missing something?
thanks for you time guys!
carholme
Re: Merc 110 Lower Unit Rebuild ?
Put the bearing and gear assy in the freezer overnight and just before taking it out of the freezer, warm up the bearing bore with a hand held propane torch, remove the gear assy from the freezer and line it up as best you can and drop it into the bore.
Gerry
sswitzer916
Gerry
awsome thank you, i actually just got done talkin about that with my roommate, but i feel better about it if someone else thinks so too. crossing my fingers
michaud500
Thats awesome! Put it in the Freezer! Im a shade tree mechanic, nothing special.
sswitzer916
bam, finally got that sucker in there! seems like the freeze and heat thing did the trick.... along with a lot of patience lol.
thanks for the advice!
