The trim on my 90 searay 3.0 mercruiser just completely stopped working. It worked fine a couple of days ago with the exception of the trim up. The trailer button worked but I didnt use it unless the engine was off. Yesterday I took off the trim switch on the starboard side of the bell housing because I found a disconnected wire. I took of the main plate and then the screw where the wires when into the trim switch. I looked around to see if it was repairable but with no luck. So I put it all back together and when I went out today to go for a ride the trim doesnt work at all. Nothing coming from the motor. I was wondering what I did to completely break the trim on the boat? Any help would be greatly appreciated.
