melted fuel tank.
Lostfisher
I recently got a 5hp Nissan 1996 with a built in PLASTIC fuel tank. Well it turns out the guy ran it hot just once and it melted a hole in the tank. I was wondering what would be the best way to plug up this hole. I was thinking of a high temp RTV but would like your guys imput on what to do in order to fix this.
NelsonQ
Re: melted fuel tank.
My opinion would to replace that tank....I wouldn't patch it
robert graham
You can't very well patch a plastic tank, just buy a new one. Good luck!
jondavies
How much damage do you think an engine fire on your boat might do?
Perhaps you could hit up the previous owner for the $70 or a portion thereof, but I'm guessing he'll probably tell you the motor was "as-is."
TOHATSU GURU
Your not going to be able to patch it with anything that will stay stuck. Pop for the new one and live a wee bit longer.
pvanv
369703162M FUEL TANK 5 HP INTERNAL (USE CAP 393700205M) $64.98 available at any dealer.
If the motor got that hot, verify the cooling system too -- check the pump and thermostat, etc.
Lostfisher
Scarred it up a bit and put some JB weld on it.Worked like a dream.
TOHATSU GURU
So will epoxy and a lot of other things....Until it pops back loose again. Boom!
Tig
Fixing my weed wacker tank has been an ongoing hobby for me. Epoxy will pop as mentioned. FWIW, RTV is petroleum soluble.
Good luck and let us know if it last the season.
jondavies
If it were me, I'd take the money I saved and spend it on fire extinguishers :rolleyes:
