mecury outboard battery wiring problem
kleger1
just removed all the batteries in the boat due to cleaning. when putting them back in, realized there are two starting batteries and one deep cycle. Have alumaweld 17 ft with 115 1996 mecury outboard. boat has trolling motor, console with guages, and livewell. put all the battery connections back in and starter turns, but would not engage flywheel. other threads have suggested weak battery or poor connections. battery was working fine when i took it out and connections were tight. wiring harness had two black wires that went directily to starter and two sets of large wires (one set of each red and black) that went forward to console. tried putting all of the wires on the starting battery--starter turned shortly and then stopped--now whole boat is dead--no juice to anything--no power trim, no console, no starter. Have checked all the fuses I can find and they all seem good. Is it possible i fried the ignition switch at the key with the cranking amps and that has the whole boat dead?
Barnacle_Bill
Re: mecury outboard battery wiring problem
Did you check the 20 amp fuse under the cowl?
kleger1
would that also kill power to the console?
kleger1
20 amp fuse by starter is good--changed it anyway. still have problem. brought battery to have checked--battery good--show 850 amps cranking. cleaned all terminals and retightened connections--starter will spin, but not engage flywheel. ????
Barnacle_Bill
Probably 95% of all starter problems is electrical. Is the battery fully charged? Check all your connections. They must be very clean and tight. Check the lugs very closely for any signs of corrosion. They can corrode inside where you can't see it and cause the problem you are having. If you know how to do a voltage drop test you could check them that way. Another way would be to temporally substitute the cables with jumper cables. If all the cables have been confirmed good, try jumping the starter solenoid. Just because it clicks does NOT mean its good. If you are sure the solenoid is good have your battery load tested, regardless of age. This brings you to the starter itself. Remove it and have it tested by your local auto electric shop. They can rebuild it for you if needed and save you some money. Let us know how you make out.
kleger1
all cables clean and tight, battery tested--850 cranking amps at test. weird part is starter will spin, i turn key back to stop position, retry and all dead-like no power at all dead. also trim will nto work as if entire motor is not getting power--but it is intermittent, wait a while, try again, and stater spins--not enough to turn flywheel though, and trim also works. could solenoid cause these intermittent power issues?
FLATHEAD MAC
CHECK ROTATION of stsarter. had same issue with '74 mercury 500 50 hp. turned out the cables were reversed, swapped cables and starter enguaged and ran like a champ.
Silvertip
Honorary Supreme Mariner
Did you clean and tighten BOTH ENDS of the battery cables? Cleaning the battery end means you cleaned only half the problem. You also didn't mention a dual battery switch. So how are these three batteries interconnected -- if they are. You said two starting batteries? Are they parallel, through a switch -- what. There should be two smaller gauge wires (#8 or 10 gauge) at the battery. Those are the accessory feed. Gauges are powered through the engine electrical system. The Boat harness (the two smaller gauge wires) should have a fuse or breaker located close to the positive post on the battery.
