Mecruiser 4.3l Help
hit4thefence
I have a 1987 searay seville. I currently purchased a new 4.3l and I have installed it. I have brand new spark plugs, distributor assembly, and fuel. It starts and idles fine but when under load it acts like its wanting more gas. Could this be a fuel pump issue? Im pretty sure timing is on but if you think this may be the cause let me know as well. Thanks.
Re: Mecruiser 4.3l Help
Ayuh,... Welcome Aboard,... What killed the old motor,..??
You might have changed the motor, 'n Not fixed the real Problem.....
Test the Whole Fuel system, startin' at the tank....
hit4thefence
Thanks for the warm welcome. I drained the entire gas tank then resupplied with new fuel. The old engine was not winterized properly. I dont understand why people do not do correct procedures and just winterize things. I purchased this boat at a great deal then said forget that old engine and replaced with new one. Im pretty sure timing is set correctly though. Im just curious about the fuel pump. Thanks for posts
dubs283
again...how do you know for sure?? did you set it using a timing light??
what are you curious about?? pressure/vacuum?? - only you can figure that stuff out, we have no way of seeing the pump or testing it for you
here is a link for testing the pump output:
http://forums.iboats.com/showthread.php?t=283269
achris
More fish than mountain goat
Check that the spark is advancing. Before looking at the fuel system, make absolutely sure EVERYTHING in the ignition system is right.
You haven't given us much information on the new engine. What year is it? Balance shaft? Vortec? What fuel system (MPI, TBI, Carb/2bbl or 4bbl)? What ignition system (Thunderbolt IV, Thunderbolt V, MEFI, ECM/PCM555)?
