Kiwi Phil
Thread starter- Joined
- Jun 23, 2003
- 2,182
Replacing Suzuki Gear Case Seal Kits
The motor was leaking water. We believed it to be from the base of the Gear Shift Rod, which is the S/S rod at the "left" of the picture, (with the roll of white tape sitting on the top of it to identify it)
Problem: re can't "split" the housing. That is where the screw driver in the right front of the picture is.
We can raise-open the front and the reat of this case, but not the centre.
There are 4 threaded studs, that the pump housing fits over...
We managed to remove one rear stud, but we can't get the 2 front studs to move.
The screw driver in the middle of the picture is on top of one of them.
Question:
How do we split the case so we can put in a new Suzuki Gear Case Seal Kit?
Do we have to remove these studs to get the case apart?
What are we doing wrong?
Why won't the case 'split' apart?
Any help will be much appreciated.
Cheers
Phillip
Question:
Cheers
Phillip
