Mechanical Steering question
Renken1600
Hi there, Still plugging along, trying to fill my head with the unkown. I have a mechanical helm with one cable going to a mercury 115 2 stroke. Should anything be sandwiched between my steering wheel and bezel? When I purchased the boat, the helm was quite wobbly... snugging down the nylon nut seemed to help but of course now it feels like I've introduced more friction into the system. I have steering wheel with keyway, mated to the bezel which is covering the mechanical helm. Should there be a washer or grease between the steering wheel and bezel?
wrench 3
If i understand what you're saying correctly, there should be an air space between the steering wheel and the bezel.
Bt Doctur
Remove the steering wheel nut and remove steering wheel
remove the 2 screws and remove bezel.
the helm unit should be bolted to a mounting bracket that is bolted to the dash
Has anyone ever taken a Mercury Ride Guide Steering Wheel Shaft out and taken to a machine shop, had the end built up with a welder and re-machined down in order to put a 3/4 tapered hole steering wheel on? I'm thinking this is the way to go and just wondered if anyone else has ever attempted to do it.
Just tired of the old skinny steering wheel
