Mc1 drive shaft question
1977 SILVERLINE
doea this shaft run in gear oil on the top. I noticed there is an oring on the shaft and there is a seal in the upper half that also runs on the shaft. Thanks.
Bt Doctur
No its there to help keep water out of the splines but its not an issue. grease the splines during the install of the lower unit.
The oil seal is in the upper unit and the smaller driveshaft seal is the lower seal in the upper unit.
1977 SILVERLINE
Can gear oil leak out of this 4 bolt housing?
im trying to chase down a gear oil leak. Thanks
Bt Doctur
That is the water pocket cover , no oil there. If its leaking down the shaft then its the upper seal thats bad.
Open that link and go to 3A-10 part # 13
