MC Alpha 1 Gen II OD leaking lube
tank1949
I have an older OD that over the winter I noticed lube residue seeping from the vents where I normally install muffs to rinse motor. I suspect seal has gone bad but do not know which one and is there a tool available for seal removal and replacement????
start by draining the lube and performing a pressure test to determine what is leaking
Bt Doctur
either the driveshaft seals or the seal under the water pump wear plate, easy fix.not rocket science here.
tank1949
Is there a tool for this seal removal and replacement????
Bt Doctur
for under the wear plate, 2 phillips screwdrivers inserted into the holes
tank1949
I replaced impeller last year but I don't recall the seal being easy to access to "pop" out. Do you have photo of what I missed?????? I have manual, which is not much good.
Bt Doctur
Bt Doctur
best to have the oem one but if you cant afford one ,one can be burned, we will disavow this action
