MC-1 interchange with Alpha 1
pcmpete
My gimbal ring has developed alot of slop, so it or the steering shaft needs replaced.
Question:
Can I use an Alpha 1 Bellhousing/Gimbal Ring assembly with the MC-1 transom plate and MC-1 outdrive?
Thanks
Re: MC-1 interchange with Alpha 1
Ayuh,... Probably, but the inner plate, may or may not work...
pcmpete
what would be the difference in the inner plate?
Ayuh,... Motor mount differences,+ stud spacing,+ count come to mind....
pcmpete
so if keep the same engine that fits the MC1 inner plate, the MC1 inner plate 'should fit the alpha1 gimbal housing?
Ayuh,... Key word is Should....
chaparall villain 2
im not positive but i believe the mc1 gimble housing and the alpha gimble have some differences i can check in my mercruiser book tommorrow but not sure that will work i believe the bellhousing would bolt up to the alpha gimble but i am not sure the mc1 drive would bolt to the gimble and work
