Max RPM with Cobra outdrive
wilndadra
Hello was wondering what the max rpm i can safely turn my Cobra outdrive. Its a 92 model in my 19 ft. Would it be OK with 5500 Rpm?.
airdvr1227
Re: Max RPM with Cobra outdrive
Need much more info. What engine?
wilndadra
The engine will have no problem with the rpm's. Its a fresh 347 10.8 to 1, balanced, stock gt roller cam etc. Just was wondering if the outdrive can take it?
Bridar
The Cobra outdrive is designed to handle up to 300 hp. I don't see a big issue with 5500 RPM, however; your gear ratios may be off if you're changing to a different powerplant.
