mastercraft fuel leak.
rob935
i have a 93 mastercraft with a 351 v8, the engine is running like a dream however there is a strong fuel odour from the exhaust, the oil is clear and compression and head gaskets are good !! just concerned that the fuel is escaping into exhaust ? if so how and what will i need to do to rectify ??
thanks guys.
Haut Medoc
Re: mastercraft fuel leak.
The only way for unburnt fuel to get into the exhaust is through the cylinders......
Even toughit is running well, I would check the plugs & wires to be 100% you are firing on all cylinders......
Also, maybe most important I'd make damn sure that the petrol smell is not coming from your bilge area.......
Visibly heck all of your connections on the delivery side of the system.........:)
That would Probably indicate that your Carb is set up Way Too Rich.......
Have you pulled any of the Sparkplugs,+ Looked to see their Color,..??....
rob935
thanks haut, its definitley not in the bilge area and the fuel system is leak free...
rob935
changed the plugs recently and all seemed fine, actually reduced the fuel odour but yet its still noticeable,
Haut Medoc
How did the plugs look when you removed them? Are they the correct heat range?
As Bondo suggests, you may be running rich.....
Is your choke working properly?.........:)
What Color were the deposits on the plugs,..??..
You Should be seeing a light shade of Coffee w/ Cream coloring.........
rob935
deposits were like you said bond-o apart from one which was darker than the rest, i have an idea that the problem may lie in the carb, either a float sticking or some thing dumping too much fuel through ??
THE BEEF
If you have one of those black plastic floats and and you do a carb rebuild change it to a brass float.Plastic one can cause a lot
of trouble.
