mariner magnum II 150
louism
Hi! I just removed my carbs (3) from outboard, and plan on rebuilding them. I need info on carb type so I can purchase rebuild kit. serial # ob314774 magnum II v6 150. Markings on carb are: 1374-5427-c on all 3, and then top carb 41-10198, middle carb 41-20208, bottom carb 41-30218. All carbs have marking of WH. If any one can help with fuel pump kit as well. Its square with markings: 14430-c1, 98766. Thank you
j_martin
Re: mariner magnum II 150
WH41 carbs. Kits are the same for all WH's. (1395-6452) Only difference between WH41 and WH41A is the idle jets. Needles, seats, and floats are usually OK. Fuel pump kit is 21-857005A1.
hope it helps
John
louism
thank you for the information John. Do you know of a product I can use to soak carb and fuel parts overnight. Also can I use automobile fuel hoses rated for carb or fuel injection to replace deteriorated hoses on carbs and block.
j_martin
You should use marine rated hose. It also needs to be the newer compound to handle the ethanol, unless you can avoid that chit.
