mariner 55hp wont start and back fireing
weggo
can any one help plaese
i went out on sunday and the idiot that was supose to be making the outboard safe did every thing right but tighten it to the boat.
any way it fell off and went under the water and got well and truelly soked.
now then it started after a lot of work and wd40.it ran ok for some time and then it started to mis fire abit and i came to a stop the motor cut out when i tried to start it it wouldnt start.
got it back home and blew the carbs out dried every thing i could get at put new spark plugs in and tried to fire it up.
after turnig it over for 5 minutes it starts trying to fire up and back fireing all the time but will not start at all.
it looks as if the spark is abit weak shouldnt it be a good crack of a spark. is there points or timeing on this motor.it ran great untill it went under water.can any one help.
also can you tell me its age. on the plate it has 55el and 663L318231
ONERCBOATER
Re: mariner 55hp wont start and back fireing
was it salt or fresh water it fell into.... did you remove the plugs before you tried to start it when it was first recovered. Was it running when it went overboard? your spark should jump a 3/8" gap and be a nice blue color. How long did it run after you got it started 1st time after retrieval? Did you pull the flywheel off and dry under there? or did you at least blow alot of air under there? and did it hit the bottom.... as in come back up with mud on it weeds ect...
weggo
hi thank for quick reply.
yes it was salt water,no i removed the plugs the next day after i tried to start it at home ,
no it was cold we were just starting to go fishing we were on the beach in about 4 foot of water it didn't hit the bottom the steering link saved it but went right under,the spark is not strong its its more like a flint spark off a lighter it just doesn't look right,after retrieval it it ran for about 5 or 10 minutes,no i dried every but under the fly wheel.
just tried to start it on the muffs today and you see smoke coming from exhaust and its kicking back and back firring trying to start i will blow some air under fly wheel and try but its been in the garage and it should of dried of i think.
M
Maxz695
Guest
I would check two things first the stator under the flywheel rust build up may inhibit the spark the gap between the flywheel and the stator are set any flucuation can affect the spark also check to see if your coils are corroded where the wires insert into them. if there are green i would either buy new ones or get PB Blaster a great corrosion inhibitor you can get at any auto or marine parts store. also use this spay inside the cilinder heads through the spak plug holes and turn the engine over without the plugs to spit the fluid out with any crap it has in there with it good luck. By the way i was having the same problem with my 2 stroke the last two days and come to find out the last time i changed the plugs i reversed the wires and it ran for a while then quit. I would get backfire no turnover. I set the wires back and vroom it runs today.
weggo
i will check all this out thanks this is a big help.il do as much as i can my self before i take it in to get seen to.ill let you know oh do you need a fly wheel tool to get the fly wheel off.thanks ,neil
weggo
its the flywheel it bust. iv been told by mf marine services who i must say is very good.
he can get the fly wheel but can you or any one ells tell me were i can get the woodruff key from fly wheel key.told they dont make it .or is there an alternative one that will fit.
carholme
weggo;
Your engine comes up as:
55 EL 663-318051 - 663-318398 1987 or;
55 EL 663-31206 - 663-32415 1974, interesting, I'll look into this further, however the parts listing below is for the s/n range.
From here:
http://www.marinshopen.se/Motorer/O...årslista/Mariner4055hp/tabid/461/Default.aspx
Parts listing:
http://www.crowleymarine.com/mercury-outboard/695.cfm
Look under CRANKSHAFT AND PISTON, item 20 and they are available here:
http://www.marineengine.com/parts/m...ponentId=1162&component=CRANKSHAFT+AND+PISTON
Gerry
CharlieB
Did you take the motor in and let them LOOK at it?
If there is not an obvious crack in the flywheel then DO NOT order a new one until you remove it for inspection.
You may have a rusted stator shorting a winding, without proper inspection and testing you may be spending money on un-necessary parts.
weggo
thanks Garry your help is more than welcome great weather and i cant get out im fed up.been told they are a good motor do you think its worth spending a bit on it.
weggo
inside were it slips on the shaft and were the woodruff key goes thats all chewed up and scored on the flywheel its self.the shaft on the motor is ok.
weggo
went on the crowley site item 20 and it comes up No dealers are currently stocking this part.ill try again i mite be missing some thing.neil
weggo
hi Gerry all sorted he got a reconditioned flywheel from a guy who builds the ariver oriva boats or some thing like that ,in Sunderland.
in the end it was nothing to do with the water that got into it when it went for a swim.it was down to a bodge job by the seller
from Scotland.all together it cost ?230 and that included a service i thought that wasn't bad.so i bet you can guess were im going on Sunday
fishing.MF MARINE SERVICES IN FERRYHILL CO/DURHAM thats the place if any one has problems ray the mechanic what a nice man.highly recommended. can i say thank you very much for all the help from every one,im going to order some keys Gerry so i have them to hand
CHEERS NEIL.
