Mariner 40 Magnum from 97 wont start
spiken
Mariner 40 Magnum 1997 four stroke G545615. The motor has run like a clock since I bought it new in 1997. Yesterday just after I started it, it suddenly died. Starting engine works fine. Battery is fine. Kill switch works fine. Switch for "Zero gear" works fine. Fuse fine (20A). Power (12V) at fuse fine. I have checked fuel and also tried "starting Gas" sprayed into the carb, but it it just stone dead. I dont think it is a fuel problem. Spark plugs looks fine but I think I am not getting sparks. I have measured for power (12V) where I can and without a manual and everything seems fine. Engine looks like new inside. To me it seems like something with the ignition-system is gone!? The electronic gadgets that are sealed with transparent plastic looks fine but I have no Idea how to check them out.<br />Best regards Håkan from Sweden
