Mariner 15hp 1980s FUEL CONNECTOR
MARK BRAY
I Need 3 Point Connector From Fuel Line To Engine.any Ideas Where To Get One From Or Should I Make New One Up?
bgbass.1
Re: Mariner 15hp 1980s FUEL CONNECTOR
you can get them at napa walmart here at iboats
MARK BRAY
Many thanks for reply. found out today that engine is 1970s and originally the third pin was for kerosine even now though its a blank.is it still the same fitting you mentioned.
bgbass.1
you can eliminate the third one and run 2
MARK BRAY
Re: Mariner 15hp 1970s FUEL CONNECTOR ?
Thanks again .I have tried a standard connector but the actual fuel spiggot coming out of engine is larger 9/32 and aligning spiggot is7/32 .Distance between centres on spiggots is9/16 .The model number is 651s001978 .tried searching on web but to no avail has this been superceded by another number? Hope not to waste too much of youir time ,thanks again
bgbass.1
look at this site www.ishopmarine.com click on parts list click on mariner click on 15a and click on model number on left side click on gas tank # 33 is end see if it looks like yours
MARK BRAY
:)Thanks once again,the connector is still available but its over $50 at least youve pointed me in the right direction for spares and info.Had a look at the cowling assembly and it shows the spiggots unscrewed .so will try removing them and replace with modern fittings .Regards Mark UK.
