Mariner 15 hp lower unit for 2 stroke outboard.
dj!
I took lower unit off to check impeller which was fine. When I tried to put back together I've run intoproblems. When I reconnect lower unit and shifting rod I can't put in gear as gear lever stuck. It appears to be stuck in gear, although shift lever in neutral position. Help!
