How's the block look between the cylinders?Pistons and cylinders looked good
No scoring nice and smooth
Taking the heads to machine shop tomorrow for a look over
Suggest getting the injectors flow testedBlock looked good with a straight edge.
#7 cylinder tried to suck the intake valve in and made a tulip out of it. Machine shop has them now and is going through them.
Dang, carb and only number 7 tuliped, that's differentIt’s carburetor
Also how do you tell if it is a Tbolt4 or 5 ignition?
Mine doesn’t say on the cover or nowhere
if your timing spec is 8 it should be at 8 in base mode not 0. It is usually on the flam arrestor and also in the shop manual.When setting the timing I need to ground the Purple/white stripe wire to put into base mode?
Should my timing be on 0 or should it be at 8 degrees in base mode?
Hey! We're tulip twins! I Tuliped #7 intake valve on my boat this past weekend too.Block looked good with a straight edge.
My purple and white wire ends near the shift plate by starboard exhaust elbow. There is a plug in the end of it I just use a jumperI got my heads reworked and have them reinstalled…..$410 later new intake valves and valve seals on all valves Exhaust valves were good and sealed good
1 question I have is my purple white wire for setting the timing goes into the wiring harness and don’t know where the end is so I can ground it. Does it run up to the dash or should it terminate somewhere else?
The purple/white wire just runs from the ignition module to the open end of the connector you ground to put it in base mode. It's all of about 10cm long....1 question I have is my purple white wire for setting the timing goes into the wiring harness and don’t know where the end is so I can ground it. Does it run up to the dash or should it terminate somewhere else?
Idle set the timing to spec which I think will be 9 or 10 deg btdc depending on vortec or notFound my purple white wire for grounding.
What RPM do you run at the set the base timing for this engine?
