Re: Need quick help on 1989 Evinrude 48, changing gear oil
I read up on this and this is beyond my comfort level. I found a local mechanic for $65/hour and he will be fixing it, changing the water pump and changing the oil for 3 hours of labor.
After that, I will have done:
- New screws/plugs/o-rings for oil
- New gear oil
- New impeller and housing
- New o-rings/seals for the 2 screws I removed by accident
- New spark plugs (did yesterday), sprayed some fogging oil into cylinders
- Cleaned/greased propeller, replaced cotter pin
- Run fresh gas with Seafoam through system, flush with water
I'm also going to clean the carbs. How can I tell if they need a carb kit?
That should about do it. It ran fine last year, so should run even better now (fingers crossed).
Bet you won't do this again.
QFT!
