Main Waterline from Watertank leak
duggan12
Hello I have a 1989 Starfire Westport 265 with a main water line leak in the sealed hull. Yes, the hull is sealed and I have no access to get into the hull to replace it or to access the damage.<br /><br />Does anyone have a sealed hull, or has had this problem. I would appreciate any suggestions<br /><br />Thanks MIKE
crazy charlie
Re: Main Waterline from Watertank leak
You may want to start by contacting the manu and find out where the tank is located and cut an inspection port into that area.Charlie
