Magnumdekes 1976 22' Starcraft Islander
Status
Not open for further replies.
magnumdeke
Re: Magnumdekes 1976 22' Starcraft Islander
I got to admit I LOVE MY JOB!!!!!! Cool Stuff to work on and a sweet shop to get stuff done in, owner of my company is ONE OF THE COOLEST CATS I KNOW!!!!, He says THIS IS MY SHOP AND HAVE AT IT!!!!!!!!!!! Sorry for the yelling, gets my point across though!!!
The man has a great heart, check this out We partnered with Paul Jr and Discovery channel to DONATE a bike to the March of dimes, That has been keeping me busy traveling with it!
This was after we filmed the reveal for American chopper
KICK BUTT company!
All right back to your regulary scheduled resto.
magnumdeke
Well it is Sunday and I decided to get some rest and gave up for the day! Me and my faithful companion did get primer on the inside of hull and I got my kicker plate fabbed up.
Winnie (winchester deke) magnum deke was my old black lab that passed two years ago
primer I used, It mixes 1 to 1, used 1 gallon of sprayable mix, still have 1 gallon for exterior
I had to paint in our wash bay because there is 40k$ worth of teak in my paint bay right now
Primer on
looks better in person than this
magnumdeke
Here is my kicker plate,
and 2x2 tube I put in for reinforcement
Enjoy your Sunday, I am going to!:D
Happy Boat Building!!!!!!!!!!!:)
jasoutside
Seriously great stuff happening right here:D
magnumdeke
Putting a coat of grey sandable primer down, It is the majic rust preventative sandable primer>
it is down pics soon
It's grey!!
HAPPY MONDAY!!!
magnumdeke
Ah just to let you all know, I have a temporary delay of game due to stupidity. Last friday I managed to hit my head hard enough to give myself a severe concussion:facepalm: Fought through it until Tuesday, went to the doc cause I found myself doing unusually dumb things and he put me on the bench for a while. So if I cant work kinda hard to justify working on the boat! Found out my head is not as hard as previously thought!:rolleyes: Oh well hopefully the headache goes away soon!
TruckDrivingFool
Now trying to convince everyone else you're not hard headed. That's the battle.
Here's hoping for a speedy recovery.
ricohman
Great thread. Hope you are feeling better soon so the work can continue.
I gave myself a concussion years ago. And it took and entire winter until I felt normal.
magnumdeke
Well I made some more progress on the Out board bracket / swim platform.
Added support for the kicker bracket and the future swim ladder, two pieces of 2x2" tube
Had to notch the piece for the swim ladder backer, weld in the way
Added a drain tube and cut out for a deck plate
Interior of the pod
Plugged up
Deck plate and cut out
magnumdeke
Stole a little of my thunder with that last picture, moved on to final grind out for paint prep,
Following pics are different grinding wheels used to complete this
Coarse
40 grit sanding disc, also used an 80 grit
Than a hook and loop backer, pad combo, similar to scotch brite, used this red (medium) and a blue (fine)
Can see how it cleaned up
And then went to the ol Aluminum eater
rinsed off out side drying, also rubbed down with 50/50 vinegar/water
I also drilled 25 mounting holes in it, ready for primer
magnumdeke
So not much more, coat of SEM primer and some high build
Also got some primer on the transom we redone, want to get color on the mating surfaces for the bracket and transom and get this thing mounted. Not there yet.
In between coats we took a grey scotchbrite pad and warm water and scuffed layers, knocking they high sides down, and wiped with acetone, My son was working in the hull doing the same.
Made up a dribble can of acetone we can fill from a big can, less evaporation
magnumdeke
Also got some of this
in here
All this was on Saturday, today Logan scrubbed the inside of hull and prepped for another coat of white, maybe spray again this weekend. Want to dry fit and drill all bolt holes for transom and bracket also. Little by little.
sprintst
Wow. You can plan a marine assault with that baby. Lots of room you've got there.
Beautiful work man. She looks battleship sturdy.
Brenn
this is looking great so far with the bracket you made and the paint work youve done.
jasoutside
That bracket looks way excellent!
GA_Boater
MD - That's some serious tin there.
bear_69cuda
First time checking your project....
Mad metal skills brutha! I'm digging this build wow....
dozerII
Holy Cow Mag, you sure made up for taking time off for the wack on the head. Looks great and looking forward to seeing this one come together.
jasoutside
Hey mag, what was that alum cleaner called again? Milk pipe cleaner was it? Where do they sell that stuff? Does it eat through anodizing? Thanks man:)
Status
