- Jul 23, 2011
- 53,243
Since redneck joe started a cooking thread and jebby started a BBQ thread......thought I should start a Magma Grill recipe thread.
Since I have not fired up the Magma on Salt Shaker yet, bear with me as I start the thread. mostly I am looking for recipes to try.
I did laser out a damper for the top at work. so that is the first hack. I dont like the adjustable mount where you need wrenches. so that soon will be changed.
i do plan on making a smoking pan to add smoke chips to the grill. may just do smoke chips in aluminum foil for now.
First think I plan on is kebabs. normally beef/pepper/onion with an ear of corn. I can prepare ahead of time and have marinating until I fire the grill up. My go-to marinade is a bit of olive oil, a bit of Italian dressing, a bit of pressed garlic, a bit of teriyaki, some worchestershire sauce and a bit of franks red-hot....... just like the commercials, I put that $#!t on everything. if I add mushrooms, I do the veggies separate from the beef as mushrooms take much longer to cook than beef.
there are dozens of fresh seafood markets on the water so you know scallops and shrimp and grouper will be in the future. For that, i will want to get a griddle.
Once I get the griddle, fajitas will also make it to the menu soon after.
Chili is a thought, however not sure I would have enough propane on board to simmer for hours. plus, I dont think I need the after effects on the boat.....
Burgers are a given eventually. nearly every bar on the water has them, so its not a priority. Same goes for Brats.
Thanks for the recipes in advance.
