m90 neon tester
doggie-dave
hi guys where can i purchase a m90 neon tester to check output of my power packs on my 85 hp v4 1979 mod johnson have done all ohm meter checks required including key switch test still no spark coils new plugs new stator ect all check out
regards david from aus
boobie
Re: m90 neon tester
The M90 neon tester went out years ago and was replaced by peak reading volt meters where you are checking the actual voltage of the components. I myself have a Stevens CD77 peak reading volt meter which I've used for years. CDI Electronics may be able to help you out or else Stevens Instrument Co. I'm sure somebody will chime in here with more ideas.
doggie-dave
Re: m90 neon tester
:) many thanks i am trying to source a stevens meter in aus seem to be few and far between this was my first try with iboat forum very nice to get a honest answer
regards david
