phillnjack2
Ensign
Thread starter- Joined
- Apr 30, 2011
- 918
ok ive got a 1995 evinrude 60hp triple
Model no BE60TLEOC
Serial no G 03751787
im trying to get the carbs and timing syncronised, but i am comming up against a brick wall.
this is what i read
the throttle should start to advance the timing before the throttle opens the carbs or the engine will
bog down with too much fuel going to carburettors..............................
well i find that is impossible to make the advance timing start moving before the throttle, due to being
told the pointer on the throttle plateto be just touching the centre of the roller as in pic below.
Now if i adjust the rod to the carbs so the timing moves first then the roller will not be incontact with
the plate.
the timing spark advance lever only moves when the throttle lever moves, and originaly this was not
even up tight against the plastic timing link dowel, but back 1/2 inch.
to be back this far would mean throttle opening before the timing advance starts !!!!!!!
what am i doing so very wrong ?
i am just going round in circles and making it worse im sure i have completely messed it all up now.
please help.
phill...:facepalm:
Model no BE60TLEOC
this is what i read
the plate.
please help.
phill...:facepalm:
