Lure Holder Tip
CATransplant
I change lures a lot while fishing, and digging in the tackle box is a hassle. I just found a great solution for my aluminum boat. I cut a 3' piece from a swimming "noodle," then hot-glued it under the gunwale beside my usual fishing position.
Lures hook right into the foam, and come right out without hanging up. So, now, I can line up my favorite lures and switch back and forth with a minimum of delay.
You could also use foam pipe insulation, but the noodles are cheaper.
HAV2FISH
Re: Lure Holder Tip
You could do like i do, i have a fishing pole for every lure. I just set one pole down and pick up another. At least thats what the girlfriend said i do. I guess she is never looking while I'm tying on a one.:D
gonefishie
Re: Lure Holder Tip
You coulda done the same thing with a piece of marine carpet and it won't wear out like a piece of foam would.
nimmor
Re: Lure Holder Tip
That is nifty ideal. I have some left over pieces of foam pipe insulation so I think I will try that.
CATransplant
Re: Lure Holder Tip
Carpet really catches the hooks, and the barbs keep you from pulling them off the carpet, I've found. No such problem with the foam stuff.
gonefishie
Re: Lure Holder Tip
It takes not much effort at all to pull the hook off the carpet in my boat.
mars bar
Re: Lure Holder Tip
Those noodles work great for my worm harnesses. With a 6' leader. I just stick the hooks in and wrap around and around.neat and tidy and they can dry too.
lowkee
Re: Lure Holder Tip
Great idea, CAT! I may try that method inside my tackle bag. Those trays just seem to become dumping grounds for my lures after a while. A noodle would allow me to easily put them back (and take them out) using one hand.
LiLGrady17
Re: Lure Holder Tip
Saltwater Fisherman has a write in tip section, & someone wrote in about using noodles to store rigs this way. They cut noodles to the length of a duffel bag & used large head roofing nails to attach the loose side of the rigs to the noodle. I'm going to set up a bag like this myself.. Possibly use different color noodles for different type of rigs..
