Lund Pro V 1775
kep1662
If I take the screws out of the center section will the floor come out or is there something else I have to do? I just bought a 1995 and am probably going to have a lot of questions. And what is the best way to get rounded out screw heads? Also is there anywhere I can get a book on this boat? 1995 Pro V SE
jigngrub
Re: Lund Pro V 1775
Pics are a must for the best advice.
Rounded of screws are best drilled out if countersunk, panheads can be removed with vice-grips sometimes.
Do you plan to replace the decking?
kep1662
Re: Lund Pro V 1775
No,the floor is fine. I used a Grabit and it worked fine. Do I have to take off the back deck to get the floor board out. I'm just trying to trace out the battery charger wires because it went bad.
