SS MAYFLOAT
Thread starter- Joined
- May 17, 2001
- 6,372
Weather got nice enough to get my wood trim all finished on my boat. The last time it was in the water was Sep & Oct of 06. When I took it out, the motor quit on me as I was loading it on the trailer. Since I didn't get a chance to start it before winterizing, I've been worried about maybe water injestion through the exhaust. All I did was drain the block and manifolds, no antifreeze like I normally do. For the last two winters, the temps gone below 0 for several days on end. That was another worry if it was going to crack somewhere. I never use stabilizer in the fuel, and my water seperator is the same one I put on for the 2 months in 06. I put 10 gallons of fresh gas in it. The tank was bone dry since I drained the gas for my mowers and other equipment. Changed the oil/filter and removed the distributor to prime the oil pump by using a drill. Hooked up the garden hose up to the line going to my raw water pump and dribbled some gas into the carb. Hit the key and she fired right up! No leaks, 160* water temp, 45# oil press at 800rpm, amp guage reading just on the + side. Boy does this make me feel great! BTW,,,,no blue, white, or black smoke,,,,none at all
After all the bad luck the past couple of months with my knee and getting my teeth knocked out,,,,,,,,bout time for some good luck. We sure did miss being on the lake last year. That was the first time in 20+ years I hadn't been on a boat. Hopefully the boat will be in the water in just a couple of weeks,,,,,,,,providing the weather don't turn to ________! Thanks to those that helped me and ridiculed me on some of my ideas a projects. Nice bunch of shipmates!...............SS
