lowrance elite 5
catfish2
My Lowrance Elite 5 led back light has gone out. I can see working by shining light on it but no back light....All updates are done and its over 6 years old so no help from Lowrance. I can see setting for light and it is at bright 10>and have done the double tap on power button and did hard and soft reset... Wondered if anyone has ever tried to fix one?
sam am I
Used to fix lots of back lights on laptops and a few FF'ers back in the day, could be as simple as a bad connection needing re-solding in that area or the inverter(usually 200V'ish electrolytic cap dries out and takes it down) is T.U.
Sometimes the EL panel/florescents can go but usually its the above. If you crack it open to have a peak, be advised ya might be breaking a sealed where they've filled the unit with an inert gas (older bottomline FF units did anyway)
Snap me a picture of the guts if you open it.......Have a meter and/or a scope?
