870 Expressmag
Thread starter- Joined
- Sep 7, 2011
- 154
Re: Lowrance Elite 4 sonar help
thank you for the explanation. i can handle knowing that i am a novice and need to learn to interpret it, i just wanted to verify my unit was not bad. also i have always used my unit on 200khz. thanks for the help guys i guess i got a lot of learning to do....adjusting is going to be the biggest challenge. i try adjusting one way or another and never know where to stop so i usually turn it back to auto adjust. i read online to set the depth range to twice the actual depth your in, then adjust sensitivity until you get a double bottom, then change depth back to actual depth and sensitivity should be correct, i tried this and never got the double bottom.
