Lower Unit
rhedges
Has anyone ever had the lower unit of a smaller outboard apart? If so, how hard was it to disassemble and reassemble?
Paul Moir
Re: Lower Unit
Sure. It was easy. Another one I did was hard though.<br />You know we're going to need some specifics. :)
mlryan
Re: Lower Unit
how small are we talking here. Small as in under 10hp? Small motors without a clutch are really easy to disassemble although some times the seals around the shafts can be tricky to remove.
marinemech1
Re: Lower Unit
get amanual read it then decide if your capable of teardown reassemble
rwcreigh1
Re: Lower Unit
not really what i would call small.first get a manual.not very old why do you need to disassemble it?
rhedges
Re: Lower Unit
Major vibration when I put it in gear. Defniatley not the prop. I bonked it a while back. Worked fine for about 4 or 5 outings. Then the vibrations started.
