Lower Unit Workbench Clamp?
cgodfrey
I'm disassembling and resealing an old 25hp lower unit. First time I've done one this big. (Lots of 3's 5.5s and 10's, but I'm branching out)
I don't have a great method of keeping the lower unit (with drive shaft and shift rods protruding out) clamped immobilized so I can put the necessary torque to the skeg/cap screws. I think the last guy put some threadlocker on them, they're in there snug.
Please show me your clever and/or obvious solutions for working on an upside down lower unit. I'm going to be doing a couple more 25s and 33s this winter, so if there's a popular commercial tool for this function, I might invest in it.
oldcatamount
I have a Black & Decker WorkMate, which is a portable table/bench with a top that opens and closes by two crank handles. The top is wood and won't hurt the paint finish. Open up the top, set the L/U in it and tighten the crank handles. Works good for small units. Also works good for impeller replacement.
Tim Frank
I use a woodworking bench-vise with 3" Styrofoam blocks that I cut.
Foam crushes well and shapes itself around LU nicely.
FMJshooter
Yep my father in law is an old time boater and he has a wood fork like that and bigger one he welded up out of square tube steel for bigger units. Both work very well!
cgodfrey
I actually found a friend with a Bob Kerr tool. It might have spoiled me for any other setup...
