lower unit will not shift??
Mercs and such
I have my lower unit taken off of my 1984 75hp mercury. For some reason it will not shift into neutral. I tried putting the shift control in forward gear then install the unit, then shift i back but it will not work.
any suggestions on fixing this i do not suspect internal damage could be something obvious.
thanks, Mercs and Such
Texasmark
Re: lower unit will not shift??
Take the lower unit back out and turn the shift shaft through F-N-R if it will go. If not there is a lower unit problem.
Put the lower unit in F. You can tell F because the prop will only turn in one direction and the overrun clutch will click as you turn it.
Put your engine control in F position.
Reassemble.
If you have no mechanical problems, it should shift.
Mark
