Lower unit questions
wilson750
I received a 88 mercury 90hp with the lower unit removed. I am going to replace the water pump and reinstall lower unit. Question is the top of the lower unit were it Mounts has some nicks where water would get in. I don't see any type of gasket or the top of the unit where it bolts back on. Is it just metal to metal?
Absolurely no need to worry here.----That area around the pump is all water when lower unit is in the water.
wilson750
Ok thanks. Just wanted to make sure it can't get into the lower unit oil.
Water is kept out of the lower unit be oil seals and o-rings on shafts and openings.---Not by a gasket between the lower unit and exhaust housing !
Do the nicks look like someone pried the gearcase off of the midsection? That would explain the nicks....
​Make sure you grease the driveshaft spline and shift shaft spline before reinstallation. Make sure to mate the driveshaft and shift shaft before installation.
