Lower Unit Oil
zippy83
Hello all,
I was wondering what type of lower unit oil should I use when I get ready to change my lower unit oil?
I have a older 1973 Mercury 50HP outboard. I am also wondering where I can get some seals for the two bolts..
Thank you
Zipp
JimS123
Re: Lower Unit Oil
Regular 90 weight marine gearcase oil. Any Merc dealer will have the washers.
zippy83
Re: Lower Unit Oil
I will find one in my area and get that taken care off
Thanks JimS123
zippy83
Re: Lower Unit Oil
hello again,
Just got back from the Mercury dealer. They told me to use the following SEA 80W-90. They said I "should be good" with this bottle.
I also released the bad oil from the lower unit. Since this is my firs time doing this I was told here on another thread to look for moisture and water. Im not sure how to determine that. I have attached a few pictures maybe someone can tell me if this is clean or not.
Also when I took the first screw out from the bottom, almost nothing came out only when I released the upper screw that is when it slowly started to come out. It was thick but at the same time its only 19F outside (35F in the garage) and the outboard was cold. It took about good 20 min until it stopped dripping. I have not put the new oil in yet.
Thanks
Zipp
tazrig
Re: Lower Unit Oil
Zipp that oil looks fine. This is what milky oil looks like:
Next time you might want to bring the engine in the house or basement and let it warm up over night before draining it. It will drain out much faster for you when warm. Same goes for refilling.
JimS123
Re: Lower Unit Oil
Bad Fall weather and the hunting season got the best of me too this year. I didn't get to winterize 2 of my boats (both outboards) until black Friday (temp was 25 in the garage). It did drain slow, but I had the new tubes warmed up in the house first and they went in just fine.
Your pic looks like dirty oil (normal). If its got water in it you won't have a problem distinguishing milky oil.
zippy83
Re: Lower Unit Oil
Thanks tazrig and Jim
I will keep that in mind next time. I guess for now I can keep the new oil inside the house for a day and then change it out.
tazrig
Re: Lower Unit Oil
Sounds like a plan. Good luck Zipp:thumb:
zippy83
Re: Lower Unit Oil
Sooo changed the oil last Saturday. I did it as instructed. Removed lower screw, removed upper screw... waited 30 min for the old oil to drain, went to the store got a pump, oil, and washers. pumped the new oil untill it started to leak out of the top hole, put the top screw in, removed the pump... put the bottom screw in.. wiped the lower unit and that was it. Yesterday I was in the garage and was lookin at it to make sure the bolts are not leaking and it was all good. Tonight I was getting some stuff and noticed that I had some oil leak, from what I was able to tell it was comming from the prop area. The oil looked dirty nothing I put in recently. I know usually when it runns you get that exhaust junk to come out, but it hasnt been running since October. However since I drained the oil it has been tilted down all the way... but again it has been tilted down for the last 5-6 days or so. I have attached a picture and put a spark plug next to it so that it can be seen how much came out.
Any idea what this could be?
Thanks
Zipp
dingbat
Re: Lower Unit Oil
Thanks
Zipp
Looks like spent fuel / carbon build-up draining out of the leg (exhaust) . Pretty normal if a motor idles or run at low RPM or any length of time.
robert graham
Re: Lower Unit Oil
I wouldn't worry about that little bit of oil...probably just from the exhaust....
zippy83
Re: Lower Unit Oil
It does seem dirty and I just went out with a flash light and poked around the prop and there is some dirty oil/exhaust still in there.
dingbat
Re: Lower Unit Oil
Does it look like fogging oil? :laugh:
The whole inside of your block is covered with that oil and fuel mixture. So much so that's dripping from inside the block, thru the exhaust and out on your floor. It's what lubricates the bearing an journals and the reason why I said 2 strokes are self fogging.
tazrig
Re: Lower Unit Oil
Bottom line Zip, nothing to worry about. If you took an eye dropper and put 2 drops of oil or gas on concrete it would spread out further than that. If a cup of the stuff landed on the floor you might have something to worry about but you are fine. Trust me on this one.
Home Cookin'
Re: Lower Unit Oil
looks like you got it down. I take it you haven't done it twice since your first post?
on a larger motor and if the equipment isn't right you can end up with the driveway looking like the Valdez, especially with a breeze. I learned to put down a pizza box to work over.
Sea Rider
Re: Lower Unit Oil
Zippy,
When you drain very filthy gear oil, with lube pump squeeze 1/4 bottle new oil gear through upper plug, rotate prop while doing so to wash all filthy oil leftovers with new oil. Lower bolt must be reemoved in order to pump through upper plug. Once all oil is drained on a pan can fill entire gear case with new oil as you been doing. Change oil each 100 worked hours.
Happy Boating
zippy83
Re: Lower Unit Oil
Could be it started to drip after I fogged the cylinders.. :)
zippy83
Re: Lower Unit Oil
I aree.. Since then I had one more dropp LOL.. Could be the fogging oil as dingbat said :)
zippy83
Re: Lower Unit Oil
Zippy,
Happy Boating
Actually this sounds like a good idea... I may end up changing the lower unit oil again to practice some more :)
dingbat
Re: Lower Unit Oil
The proper way to change gear oil is when the LU is still warm. The oil flows a lot easier minimizing retained fluid the particles are still suspended in the fluid instead of falling out of suspension and collecting in recesses and such that don't drain when the fluids are cold. Make sure you have a magnetic drain plug as well.
If the inside of your LU is that dirty, fill it up and run it for a couple of days before changing it again. Once clean it will stay that way unless you have mechanical tolerance issues or the fluid is contaminated. I change my LU oil every October. Most years there is still a tinge of green left in the oil even after 200-250 hours of use
