Lower Unit oil leak 70hp 1987
Steele329
I'm leaking a small amount of gear oil from the top of my lower unit where the lower meets the mid section. Just noticed this today. Tried to take a pic but having problems uploading. Any ideas what may cause this? Any help appreciated
Steele329
[No message]
Chinewalker
Are you sure it's gear oil? Oil doesn't generally leak upwards. The oil inside the lower unit is all well below the seam. More than likely, it's unburnt fuel/oil mix leaking from the exhaust seal between the leg and gear case housing.
Steele329
I smelled it its definitely gear oil. It's only one side and very little. Not even running down the side. I posted a pic in the comment of this thread
The sensible / common approach is to pressure test the gearcase to look for leaks.----If the seals are original it would be wise to install a seal kit.----Much cheaper than gears , shafts and bearings.-----Seals do wear out over the years !
