massimofinance
Thread starter- Joined
- Oct 30, 2004
- 508
I have a 2001 Searay sundeck 2210 inboard outboard MerCruiser 4.3 engine; everything runs fine. On the aft deck there is a hidden switch (under the air intake area) to raise or lower the lower unit; likely a trailing switch. I also have a switch to raise or lower the lower unit on the throttle and the throttle has a trailer lifting button to get it a tad higher. The switch in the aft deck does not work any longer; when you try to raise or lower the engine from there you hear a click coming from what I think is the solenoid. The switches on the throttle work fine. I believe I have two solenoids back there. Fair to assume one is for the aft deck switch and one is for the throttle switch? Assume the aft deck switch solenoid needs replacing? It’s a tough spot to get to, so should I replace both while back there? Thank you.
Sent from my iPhone
Sent from my iPhone
