Hi
I have a 1973 Evinrude 85HP, Model 85393M
Last fall, I changed the lower unit oil, fogged the engine, then tilted the motor up (using the transom saver) for indoor winter storage. I just got the boat out of storage, and was doing some prep to get it started this spring.
I removed the transom saver and lowered the motor as I checked for strong spark, changed plugs, etc.
Then I noticed about 1/8 cup of lower unit grease/oil coming out of the lower unit by the propeller. (It was not leaking at the drain or fill plug)
What is your guess...is there a seal in front of the propeller that can be changed to fix this...or does this require a major tear down of the lower unit?
Thanks for any advice.
