Lower Unit Gear Lube oil Change
LKG4ME
What size thread is used on the screw on the lower unit of a Volvo Penta 2009 SX-A when changing the gear oil - the one down behind the prop
DO2G
Any chance you have a picture? I can’t find the drain plug on the SX-A.
muc
"Retired" Association of Marine Technicians...
Yes, the drain plug is behind the prop.
The level check plug is behind the plastic cover, near the shift arm.
Tristador
3/8-16 is the thread side on my DPS-A drain plug.
Check to see if the part numbers are the same between the two outdrives.
