Lower unit fill/drain plug gaskets
crazy charlie
Changing lower gear lube in my 2000 200hp saltwater series for the 1st time.I have mercruiser gaskets of several composites , evinrude/johnson gaskets in both plastic and rubber , but never got any Yammy gaskets.im ready to use what i have unless someone with factual reasons why i should get Yammi gaskets chimes in. Not lookin for opinions here,just facts.Thaks and sorry for being so frank..Charlie
GA_Boater
Most lube pumps come with an adapter for Yamaha plugs. So the threads are different - The gasket, no idea.
Pull the vent plug and see if any of your stock of gaskets fit. I'm being Frank, Charlie. :D
GA_Boater
Did any fit the vent plug? I'm being Jimmy today, Charlie. LOL
crazy charlie
evinrude and mercruiser gaskets fit the fill/drain plug .Im gonna use what I have ,especially since most businesses by me are closed.Charlie
crazy charlie
BTW I may not have been perfectly clear .What i am referring to is the gaskets for the drain and fill plugs .
GA_Boater
So was I. :smile: We were on the same wavelength.
Sea Rider
If the outer gasket diam, middle hole diam and material are same, why not use what you already have...
Happy Boating
