1998 90hp cross flow
Thread starter- Joined
- Apr 22, 2009
- 1
I have a 1998 90hp cross flow outboard with the lower unit removed for water pump replacement, and I noticed that when I spin the drive shaft by hand (clockwise), it feels weird...i can hear and feel it almost ratcheting ... i.e. not spinning buttery smooth. It spins easy otherwise, but not what I expected.
It's smoother when I lift slightly, but never completely smooth. This happens in F, R, and neutral. There is about a 1/16th to 1/8th inch vertical play with the shaft.
The prop shaft spins buttery smooth in neutral, but when in gear and I spin the prop shaft, I can hear & feel the same "symptom".
I have had no problem with it in the water to date, and other than having to use controlled force removing the seized impeller, I haven't done anything to damage it. FWIW, it passed pressure and vacuum test and the fluid looked good.
There is noticeable side to side wiggle or movement of the drive shaft with the water pump removed, but I have read that's normal.
the manual I have has no specs or end play tolerances or description of how it should spin, so I have no idea if this is normal or if I have a problem. I also can't remember testing it when I first removed it before dis assembly of the water pump, so I really have nothing to compare to.
Any ideas??
Joe
Any ideas??
Joe
