Lower Transom Bolts on Alpha 1
Mark Jones
Just finished rebuiding the transom (thanks to this forum) of my 1989 Caravelle to repair rotten transom caused by corroded lower transom bolts and a leaking Y-pipe. I'm ready to install the gimble housing. I have a fresh gasket and fresh hardware. The lower bolts are the aluminum carriage style with threads for anodes. My question is: For these lower bolts, is the gasket (that is included with the bolt kit) between the square carriage head and the gimble housing sufficient or should I apply some sealant in addition to the gasket? I?m just paranoid of having another leak, but don?t want to compromise anything either.
Re: Lower Transom Bolts on Alpha 1
Just finished rebuiding the transom (thanks to this forum) of my 1989 Caravelle to repair rotten transom caused by corroded lower transom bolts and a leaking Y-pipe. I'm ready to install the gimble housing. I have a fresh gasket and fresh hardware. The lower bolts are the aluminum carriage style with threads for anodes. My question is: For these lower bolts, is the gasket (that is included with the bolt kit) between the square carriage head and the gimble housing sufficient or should I apply some sealant in addition to the gasket? I’m just paranoid of having another leak, but don’t want to compromise anything either.
Ayuh,.... It's Unnecessary, but do whatever makes ya feel good,...
