Foreverstrung
- Mar 30, 2012
- 12
I'm havin some issues here and could use all the help I can get. I've just replaced the Impeller on my '01 Mercury 200 2 stroke carbureted. Lower end came off easy enough. Had a friend with experience helping. Re-assembly just isn't as slick. Impeller kit installed nice. Everything is lined up, greased. The driveshaft is straight and true. It has not been tweeked, we've been very careful. The spline is not entering the flywheel. There appears to be a "sleeve" like bushing or such that the shaft would fit up into, right before entrance to the flywheel. Well it had slipped to the downside of the shaft hole opening following gravity. Had a "half moon" like line up where the spline would enter the flywheel. Blocking the spline/shaft from entering. With a long probe we could slide it back into place, it is very loose, but only with the motor in the down position and no way to hold it securely in place as the motor would go into the upright position to install the lower half. It, the bushing in question, could not be removed from the shaft hole as I could see......
