lower crankshaft seal removal
Honorary Supreme Mariner
If you found the spring from the crankshaft seal it definitely need too be replaced.
harley 1028
That's what I thought for sure .has to be away to remove assembly with out taking the whole power head apart.that lower crank assembly has to come off independently just not sure how no one seems to know???
harley 1028
It's not the 0 ring below the spine that is there it's on the outside of the chrome piece can see a Grove in the rubber seal that protrudes through
I know exactly what you are working on.---I have just never removed that housing the way you want to do it.-----Work carefully as that housing may break. ---Those 4 inner bolts have to come out.
Looks like that part has been updated.---You might want to order the kit.----Only $200 or so.----Just pry it out anyway you can.
You remove the housing and I suggest replacing the housing with the updated part !
F_R
So, you have not removed the four bolts yet? It dang sure won't come out until you do. Then it just might lever out easier than you think. You won't know till you try.
BTW, as you remove the four bolts, screw some threaded rods into a couple of the holes, just in case. You will need the threaded rods anyway when you go to reassemble it. They keep the holes in the plate aligned with the holes in the housing.
harley 1028
Could you suggest any other place I might find out the proper procedure or someone else that might know?
Rustywrench
Well I have been there and done this, but the top main mostly. A little easier to get at. Besides getting it out they are very hard to put back in. The housing has two big fat o-rings around the circunference of the housing. It is very difficult to get them to squeeze back into the crank case. If you break what you have no problem I have plenty of them you can have! Of course I am usually rebuilding the powerhead when doing this & the whole motor is apart. Drilling a hole for a slide hammer or puller? Choose your medicine. I'm here to help any way I can, but first time on this forum. Hang out on others. F_R know how to get in touch with me from AOMCI.
Rustywrench
Oh, yes pull four inside bolts as you suspected. No where for inside retainer plate to go. Line up bolts are handy when you go back together (1/4" X 28). The retainer plate fits up inside the aluminum housing when it goes back together. Also fits around lower crank bearing. It's a busy area! It's slow & steady going back in. Can't rush it at all.
When you put a couple of ounces of oil into the lower cylinder does it pour out the bottom seal ???
harley 1028
First of all thank you Rustywrench and racer one and FR .I really appreciate all the information - great Help .As far as putting oil in cylinders and checking for leak no I didn't do that as in the pic I can see the seal is bad plus when I removed the power head the inner spring from the seal was off and laying on the drive shaft plus the seal is pertruding out of the housing as seen in the pic I posted so no doubt to me that the seal needs to be replaced.thanks to all again and I will post results and procedures when I get it done hopefully today
Rustywrench
Those Viton seals are very robust. Besides you seeing a spring around the driveshaft I would want to know for a fact it was bad? The seal lips protrud out of the case like that normally. Hate to see you go to all this trouble with no improvement.
