lower crankshaft seal removal
harley 1028
just pulled power head 1996 225 Johnson to change to short shaft and realized the seal on bottom of crankshaft is bad need help removing the assembly removed the eight bolts on exterior of assembly how does this come apart ????did not remove the 4 center bolts have seloc manual but doesnt say anything about how to remove the assembly any help is greatly appreciated
Honorary Supreme Mariner
Those 4 bolts need to be removed to get that housing out.
Don't know , I have never replaced a seal using that shortcut.--Replaced lots of bottom crank seals.-Post picture of that housing.
F_R
Neither have I on that particular model, but by the picture it looks similar to lots of others. So I'll take a stab at it. Are there a couple of places around the outside edge that you can get a couple of screwdriver tips under it and gently pry / rock it out?
harley 1028
here is assembly
harley 1028
no not really thought mabey use puller in the 4 holes against the crankshaft
harley 1028
I believe the 4 holes are into a ring on the other side of bearing and puller would pull it all off ???? hate to try afraid of breaking something
F_R
The four holes do go into a retainer ring above the bearing. BUT the bearing has a snap ring below it, so the retainer ring & bearing cannot slide off. In other words, the bearing and retainer stays put and you slide the bearing housing off of it.
F_R
I'm not there so can't put my eyeballs on it, but I still think the secret is to lever it out. Maybe by rotating the housing, it will give some place to lever under.
As a last resort, run a (bottoming) thread tap into two or three of the eight holes, and use a puller with bolts threaded into the holes you just tapped.
Curious----How did you determine that the lower seal is bad ??
harley 1028
I found the o ring spring laying there off the seal when I pulled the power head off
harley 1028
The assembly has ears on it all the way around it that fit in groves so no way to rotate it at all someone has to have removed one of theses before .hopefully
the o-ring is not part of the crankshaft seal.--is there a groove below the spline on the driveshaft ?---or the o-ring inside the crankshaft spline ( if equipped ) can be replaced.
