BoatNoobie
- Jun 17, 2009
- 314
Break Out Another Thousand
Has been so awesome so far.
So here is the back of my 2005 Lowe FM165 boat.
I've owned my boat for a little over a year now, 2nd owner. I did a little cleaning today. Anyways you see the splashwell drain holes. Well the one on the left side looked like it has a lump of bird **** or dirt clinging in the hole. So I poked at it with a stick to remove it. I poked at it and it's not coming off. I look at it closer and see what looks like a hole.... I grab a small screwdriver and poked at it. The edge starts to bend.... FFFUUUUU. It almost looks like a screw was trying to come through the hole from inside the transom, from the shape of the damage. So I opened it up a little more and start picking inside the hole. Scratched around until I got solid wood. When I first started picking at it, it was coming out this gray color sand looking think. Went maybe about 1MM deep until I hit fresh wood.
Here's after I finished scrapping.
So after I noticed the damage, I checked out the other drain holes. In the original hole, I noticed 2 huge zit like bumps.
And it appears I have a hole where my transducer wire is using too, but luckily it's on top so less likely for water to get in.
I sanded down the hole I was picking at and filled it with Marine-Tex that I bought from West Marine.
Does anyone else have this issue? It does appear to be counter-productive to use wood in an aluminum boat. Someone is saying it's pressure treated wood, which eats away on the aluminum. So basicly it's a ticking time bomb.
Mod EDIT: added back original post. No idea why it was deleted once repair was made.
