burtonrider11
Thread starter- Joined
- Jul 28, 2005
- 178
Just took out our new to us Powerquest 260 with 454Mag EFI yesterday. Boat starts and runs fantastic. However, I noticed that when running back to the dock, when I turned on the nav lights (green/red and white stern) it dropped my volts low, both on gauge and on my GPS. In addition to that, it seems to affect my gauges as tach, oil pressure, temp, fuel all went up. If I turned the lights off, they went back down. I could repeat this process with the same results. It didnt matter if we were idling or 3500RPM.
There are two batteries with battery switch. It looks like this was wired up to have a starting battery and an accessories battery. Not sure if it ties in with that. One battery was new in 2018 and I'm unsure of the 2nd.
I also noticed that when I was running in the driveway, I could hear a "clicking" sound and the volt meter would drop with each click and then come back up. Click was every 5-10 seconds or so.
My thoughts are that perhaps the alternator has a bad/corroded connection or is bad itself. Perhaps batteries are in need of replacement?
One last piece, I noted that when boat is OFF, I can have the stereo on (deck, amp and 4 speakers) and if I turn on the docking lights, it cuts off the stereo. This makes me think that perhaps a battery is going bad - dropping the volts enough to cut out the stereo when something else draws. But it doesn't make sense as the boat starts perfectly. Definitely appreciate any help here!
