low compression
gig
I have a 1967 6hp Johnson outboard the compression was low so i replaced the rings but it didn,t increase the compression very much before it was 40psi after it was 75psi any ideas
12Footer
Re: low compression
It's normal for the compression to be lower than normal right after a ring job.<br />The new rings must "seat", or form to the walls of the cylinder walls.<br />You will get some blow-by until they do,usually after about 4 hours break-in.<br />Use 32:1 mix for the first tank,and carry an extra set of plugs (because they might foul on the oily fuel).<br />You may also have a reed stuck open on a glob of carbon. Try running some decarb thru it if your compression doesn't pick-up to specs after break-in.
