EricKit
Thread starter- Joined
- Aug 31, 2009
- 81
EDIT: I changed the title because I've realized I need to change out the intermediate bearings and pull the engine, so I'm looking for help on that. The main information on that starts on page 2.
So it's making this sound in the water, in idle, and not on the ear muffs, but it didn't start making this sound unti I put it into gear in the water. I then brought it home, and ran it on the muffs again to see if it made the sound, and it still does but much quieter, and the sounds is getting better. The sound is coming from where the outdrive connects to the engine maybe. I can hear it from where the engine is pretty good near the back side and in the outdrive where it goes into the boat area. More RPM's makes it louder.
I'm wondering if this sound is the engine knocking from too low of a grade of fuel with the added force of water against the prop when I put it into gear, but I dont' see why that would matter.
I'm confused because it sounded fine on the muffs, fine in the water in neutral, then awful once put into the gear, then awful in netural in the water, then just kind of bad on the muffs once we got home.. getting better as time went on.
