- May 16, 2009
- 9,456
Re: Loss of spark under load.
Also check for full 12v at the lanyard kill switch wiring and at the wire harness cannon plug at the engine.
Sounds like your GPS is connected up to your/a purple wire under the dash for 12v power? If so, like bruceb58 mentions, Check for good 12v + at the ignition switch, especially the purple wire as that is heading back to your coil.I just need to find where it's happening. My volt gauge always reads 12.5-13.0v when running. I use the readout on my GPS which is always 13.4-13.8v.
Since you should have the have thunderbolt IV ignition system, you should have full 12v at the coil. As a test, You may want to disconnect the purple wire at the coil, choke, alternator to make sure non of them are restricting 12v flow.Today I checked purple wire at the coil and found it was getting 9.5v with the key on, once the engine was running, coil voltage went up to 10.5v. I found the rest of the electrical system getting 14.3v.
Coil voltage remains the same, are my readings within spec or is it supposed to see at least 12v at the purple wire?
